1993 Audi 100 Changing Transmisison Fluid 1993 Auid 100 CS
1993 AUDI 100
14,300 MILES • 6 CYL • 2WD • AUTOMATIC
TURNYFACE
I've been contemplating a change of the transmission fluid in my car for 4 months now. The car is kind of sluggish when it comes to shifting and recently, I've been experiencing a problem with the car not wanting to get out of 2nd gear. I just turn off the car and then turn it back on and don't have any problems.
I talked to an Audi Service Specialist at the local Audi dealer in my town and because the car is old with high mileage (143,000) and has never had the fluid changed, he recommended not doing transmission fluid change because the sludge that's cleaned by the detergents in the new fluid washes into the pan and then picked up by the filter, which can clog it and cause transmission failure.
I was wondering what other people thought about this and if there is a way around it, such as flushing the transmission fluid, letting the car run for a bit and then re-flushing it, in an attempt to prevent the sludge from entering the transmission? Let me know what you think. Thanks.
T
Jul 1, 2010 at 3:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You will first need to inspect the transmission fluid. If it is a dark brown or black color than it needs replacing. If it has a burnt smell to it than it needs replacing. If it has metal shavings in it than it's a sign that the transmission may need overhauled soon. If the fluid seems fine (none of the above conditions) than there is no need to replace it.
Oct 20, 2010 at 6:31 PM
