1992 Audi 100 Timing. Pleas help
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHUCK1ES
i just changed the valve cover gaskets and the water pump and now the car will turn over but not start. i had to take off the timing belt and i didnt know you needed a crank holder. I need to know how to adjust the time and how to a line the marks? it is not getting spark. after it wouldnt start i changed the plugs and wires. i tried to find the repair manual put can only find the one that is for all the 1992 Audi 100, but the v6 for some reason
Mar 12, 2010 at 9:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2908.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_767.jpg
Nov 8, 2010 at 10:37 AM
