1992 Audi 100 how to replace the water pump
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANIGOMEX
I want to replace my water pump, because when i start my car, after a while it shows me a overheating message on the message board, and it does not have a hot air. i think it the water does not circulate. Or do you think it can be the thermostat?
thank you!
Mar 8, 2009 at 5:49 PM
  • 75,988 POSTS
Replace the thermostat and test the water pump see below
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
Mar 8, 2009 at 6:46 PM
