Van starts but does not move
100 MILES • V6 • 4WD • AUTOMATIC
WEST911
Good day,
The van's engine start well but it cannot move when i put the jar and raise it.
What is the course?
Jul 18, 2020 at 12:24 PM
Good morning,
Does it move in reverse?
How long since you changed the fluid and filter? I would start there to see if the filter is clogged not allowing fluid to the front pump.
Beyond that, it sounds like an internal failure in the transmission.
Does it make any noise when you put it in gear?
Jul 18, 2020 at 9:40 PM
WEST911
It started yesterday , it was not like before. Now it shuts off not make noise when you put it on gear.
Jul 18, 2020 at 9:48 PM
Okay, I would start by changing the fluid and the filter.
Changing A/T Fluid
1. Warm up A/T fluid.
2. Stop engine.
3. Drain A/T fluid from drain plug and refill with new A/T fluid. Measure amount of fluid drained and refill with equal amount of new fluid.
Fluid grade:
NISSAN Matic "D" (Continental U.S. and Alaska) or Canada NISSAN Automatic Transmission Fluid.
Fluid capacity (With torque converter): 9.4 l (10 US qt, 8-1/4 Imp qt)
Drain plug:
Tightening Torque: 29 - 39 N.m (3.0 - 4.0 kg-m, 22 - 29 ft-lb)
4. Run engine at idle speed for 5 minutes.
5. Check fluid level and condition. Refer to "Checking A/T Fluid". If fluid is still dirty, repeat steps 2 through 5.
Jul 18, 2020 at 10:04 PM
WEST911
Okay.
Jul 24, 2020 at 4:35 PM
Keep us updated with your results.
Jul 24, 2020 at 8:09 PM
