At operating temp. truck sputters and stalls when at a stpp.
1997 DODGE RAM
95,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
LAURENS DAD
Replaced iac, tbs, crankshaft position sensor and the fuel pressure regulator. Cleaned the throttle body and replaced the throttle body gasket. Did the "cigar test" to check for vacuum leaks. Exhaust is a little louder than usual. Some carbon around the connection between the cat and muffler. Thank you for any advice you may have.
Dec 21, 2014 at 4:15 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first. should be 44-54 psi at idle if below that replace pump.
Dec 21, 2014 at 7:53 AM
