No power to the fuel pump
119,000 MILES • 4.3L • V6 • 2WD • MANUAL
BRCOPELAND
  • 28 POSTS
I have the truck listed above 1500. It is getting no power to the fuel pump. I've replaced the fuel pump, fuel filter, the throttle body. If I put gas in the throttle body it will fire right up. But shut off after it burns off the fuel. I don't know what else to do. please help
Aug 30, 2019 at 5:08 AM
Good afternoon,
Do you have a voltmeter to do some checks? I attached a wiring diagram for you to view and need to do some tests.
Aug 30, 2019 at 5:35 AM
BRCOPELAND
  • 28 POSTS
Thanks for the help. Got it fixed was a bad wire going to the pump.
Aug 31, 2019 at 5:32 AM
You are welcome.
Always glad to help.
Aug 31, 2019 at 5:37 AM
BRCOPELAND
  • 28 POSTS
Now my next problem is I replaced the clutch master cylinder and slave cylinder but the clutch is still not working. any ideas would be very helpful?
Aug 31, 2019 at 9:05 AM
Okay, by the site rules, I can only address one issue at a time.
Please start a new question at the beginning and I will be glad to help.
Aug 31, 2019 at 9:19 AM
