Front brakes lock when attempting to brake
145,000 MILES
JIMCAR
Front brakes locking when I press the brakes and do not release. I changed the master cylinder and the hydro-boost and the problem still exists. please some body what I can do?
Feb 5, 2018 at 6:35 PM
Good morning.
Check the front brake hoses that attach to the calipers. it is common for them to become restricted and not allow the brake pads to release.
Feb 5, 2018 at 6:41 PM
JIMCAR
Thanks very much. I will check and let you know .
Feb 5, 2018 at 7:12 PM
You are welcome. keep us updated.
Feb 5, 2018 at 7:21 PM
JIMCAR
In the same van if the proportion valve is not good can that be what causes the front brakes to lock?
Feb 6, 2018 at 9:09 PM
yes it can, but it controls two wheels so the other wheel which in your case would be the opposite rear.
Feb 6, 2018 at 10:09 PM
