Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Vauxhall
Astra
Engine
Mass Air Flow Sensor
Replace/Remove
MAF sensor fault
2008 VAUXHALL ASTRA
60,000 MILES • 2.0L • 4 CYL • TURBO • FWD • MANUAL
ANDREW PARSONS
MEMBER
1 POST
VXR map sensor reading -40 on live feed. Have changed the part as well as the MAF but problem is still there. Spanner light on dash.
Jul 7, 2017 at 4:00 AM
Experienced Mechanic
It sounds like you have one of two problems, first would be a vacuum leak and the next would be a plugged catalytic converter.
Here are two guides that will help you get the problem fixed.
and
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jul 9, 2017 at 12:19 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
