asd problem
183,000 MILES
JD2012
spark but no fuel or injector power. new dist. crank sensor, relays and fuel pump. it runs when i spray fluid into throttle. alarm seems to be working fine. why wont it start
Apr 23, 2013 at 5:58 AM
HMAC300
  • 48,601 POSTS
check your fuel pressure it either doesn't have any or it very low if it's a2.5 should be 47-51 psi 2.4l 48psi key on engine not running scan tool activated.
Apr 23, 2013 at 6:06 AM
JD2012
would this put car into shutdown mode and no power to fuel injectors
Apr 23, 2013 at 6:51 AM
HMAC300
  • 48,601 POSTS
yes
Apr 23, 2013 at 8:29 AM
