Are the rear tires suppose to lean inward
1998 TOYOTA CAMRY
200,000 MILES • 4 CYL • FWD • MANUAL
DAVID2404
I have a front wheel drive 98 Toyota Camry. The rear tires lean inward a little. I was told by one person that they are NOT suppose to and would need to be slotted so they would be straight up and down.
Another person told be that on a front wheel drive the rear wheels ARE suppose to lean inward a little.
HELP, which way is correct?
Feb 15, 2016 at 6:17 AM
WRENCHTECH
  • 20,761 POSTS
You need to have a wheel alignment done if you have any doubt. You can't just go changing things like that as you will through out the whole alignment and tear up the tires. The rear Camber spec is 1/2 deg negative so there is supposed to be some tilt. Every car has different specs.
Feb 15, 2016 at 7:03 AM
