Changed fuel pump and car still will not start
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
MANDY HALL
But will however start and run when I put gas in the intake but quits when runs out. Would the Anti theft lock system have anything to do with my issues? If so how would I go about resetting it with key?
Aug 27, 2019 at 11:57 AM
  • 110,248 POSTS
Welcome to 2CarPros.
If the anti theft was an issue, there would be no spark. If it starts with starting fluid, you have spark.
Have you checked fuel pressure? Have you checked the injectors for a pulse signal?
Here are a few links to help with checking those things:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Let me know if those help or if you have other questions.
Aug 28, 2019 at 12:25 PM
