Engine shut off while driving and will not restart
150,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DMBRYANT99
Daughter was going to work the other day and car shut off. She put it in park to see if it would start back up and would not turn over just like a dead battery and would not come out of park. Had it towed and the driver had to crawl under the car and take it out of park. I have tried just about everything to try to reset the anti-theft system/pass-lock. I have used both keys and key-fobs that came with the vehicle and am very stumped now.
Jul 30, 2020 at 2:48 PM
  • 110,248 POSTS
That doesn't sound like an anti-theft problem. Does anything electrical work?
Jul 30, 2020 at 3:10 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial for you to view for anti-theft system reset as a start:
https://www.2carpros.com/articles/how-to-reset-a-security-system
After viewing scroll the bottom of page to find Chevrolet.Let me know if it works and we'll go from there.Hope this helps and thanks for using 2CarPros.
Jul 30, 2020 at 3:12 PM
DMBRYANT99
All lights, radio and all works. No fuel pump, no turning over.
Jul 30, 2020 at 7:02 PM
  • 110,248 POSTS
I need you to check three fuses. In addition to checking the fuse condition, confirm there is power to them. Here is a link to help with that:
See pics below for fuse identification and location. I highlighted the ones to check in the under hood fuse box.
Jul 31, 2020 at 2:14 PM
DMBRYANT99
There is power going to 34 and 22 and not to 17.
Aug 4, 2020 at 10:40 AM
  • 110,248 POSTS
Fuse 17 is the crank fuse. It should have power when the key is in the start position. You will need a helper. Or, have you already checked it that way?
Aug 4, 2020 at 3:27 PM
DMBRYANT99
I want to thank you guys for the help. After doing what you guys have posted and nothing was working. I was doing some more checking and come to find out it was it was the ignition switch. It's weird how a part like the ignition switch can act so much like something else and be so much of a pain in the rear. thanks again for the help.
Aug 6, 2020 at 11:31 PM
  • 110,248 POSTS
Glad to hear you got it figured out. Yes, they can be a pain. LOL
Please feel free to come back in the future if you have questions.
Aug 7, 2020 at 3:54 PM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, that was a strange issue.Glad you got it figured out.Thanks again for using 2CarPros and hope you will use our site again in the future.
Danny-
Aug 12, 2020 at 1:10 PM
  • 110,248 POSTS
Are you sure the battery is charged? If the alternator wasn't charging, driving would drain the battery.
Do me a favor. Try this little test at home:
Dec 11, 2022 at 10:44 AM
  • 110,248 POSTS
I suspect it is a very similar issue to the original post. I need you to do me a favor. I need you to start a new thread. We try to keep the threads specific to one type of vehicle. In this case, you are a year newer.
We do this so it is more helpful to others. I truly hope you understand. Simply copy and paste the posts you have already made to this link, and someone will be happy to jump on it for you.
Again, I hope you understand and know I appreciate your doing this.
Dec 11, 2022 at 1:30 PM
