Antifreeze mystery leak
210,000 MILES • 1.6L • 2WD • AUTOMATIC
TRISH78
I add water/antifreeze and within driving it ten minutes the water light comes on. Temperature gauge is just now starting to go a tiny bit past half. Replaced a shifting sensor but wiring was kind of bad. It also shifts hard, if I press the gas to hard the rpm's go wacky and it bogs. Help!
May 29, 2019 at 11:50 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Have you checked to confirm the coolant isn't entering the engine/oil? You may have a bad head gasket. Also, is there white smoke coming from the exhaust?
Here is a link that explains how to test for a bad head gasket. Let me know what you find. Note that I am adding this because you described it as a mystery leak, so I assume you see nothing leaking.
https://www.2carpros.com/articles/excessive-smoke-coming-from-the-exhaust-pipe
Take a look through those links and let me know what you find.
May 29, 2019 at 12:53 PM
TRISH78
Yes the oil is fine, there is white smoke coming out exhaust. Not a lot but noticeable.
May 29, 2019 at 1:37 PM
  • 110,248 POSTS
Welcome back:
White smoke from the exhaust is usually caused by coolant entering the combustion chamber and burning with the fuel. Most commonly, that is caused by a bad head gasket.
Try to perform the checks listed in the link I added above. Let me know the results.
May 29, 2019 at 1:39 PM
