Intake manifold leak?
140,000 MILES • 4.6L • V8 • 4WD • MANUAL
ROBERT LOUDERMILK SR.
  • 12 POSTS
I asked what the part was that the thermostat housing was bolted to, and a mechanic answered it was the water pump. I disagreed and after researching it looks like the crossover. Could this be right?
Oct 28, 2019 at 5:56 AM
The thermostat housing bolts to the intake manifold. Take a look at the pictures attached for more detail. Let me know if there are more questions. Thanks
Oct 28, 2019 at 11:56 AM
  • 12 POSTS
You are right. Thanks. How do I remove it. The bolts are on the bottom side of the manifold. Appreciate your help.
Oct 30, 2019 at 12:04 AM
This is part of the manifold and is not removable separate. It is a single molded component.
Here are the steps to remove the intake manifold. Let me know if you need more info.
Oct 30, 2019 at 11:11 AM
  • 12 POSTS
Thanks. I watched it on YouTube. The guy had a new intake with built in rubber gaskets. No gasket sealer involved. Looked easier.
Oct 30, 2019 at 11:44 AM
  • 12 POSTS
Where do you live man? I'll just let you do it. Thanks again.
Oct 30, 2019 at 11:46 AM
Haha. This is a little involved but not a bad job. I would do it but I have a job where I don't have to get my hands dirty anymore and I do this on the side. I like having clean finger nails too much to go back to actually turning wrenches.
Let us know if you need anything else.
Oct 30, 2019 at 11:51 AM
  • 12 POSTS
is there a sequence and what is the proper torq of the manifold bolts?
Oct 31, 2019 at 4:53 AM
Yes. The 14th attachment above. I reattached it here.
Oct 31, 2019 at 10:16 AM
  • 12 POSTS
Thanks, you've been a big help.
Nov 5, 2019 at 2:14 AM
  • 55,770 POSTS
KASEKENNY1 is one of your best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Nov 5, 2019 at 2:15 AM
  • 12 POSTS
Yes, I agree. He is very good.
Nov 6, 2019 at 8:08 AM
  • 12 POSTS
Thanks for your help Kenny. I finished the intake manifold job today. I also replaced the serpentine belt and spark plugs.
Feb 24, 2020 at 2:40 AM
