antifreeze holding tank
179,000 MILES • 1.9L • 4 CYL • FWD • AUTOMATIC
BUCKROSS
Is there a hose underneath the holding tank on a saturn engine? Would you be able to have a diagram of the radiator and hoses on an 2002 saturn sl2 enginge? If so, can you email it to me?
Jan 6, 2016 at 9:52 AM
SATURNTECH9
  • 30,869 POSTS
There is a hose at the bottom of the tank which is clearly visible with the tank in place.Also a small hose at the top of tank.Those are the only hoses attached to the tank.I have never seen a coolant hose diagram for that car.What are you trying to figure out?Those tanks do crack and leak when they age sometimes.
Jan 6, 2016 at 11:20 AM
BUCKROSS
I was just wondering if the hose could have busted. So, I think my best bet is to replace the tank. Thanks!
Jan 6, 2016 at 10:01 PM
SATURNTECH9
  • 30,869 POSTS
Don't forget the radiator cap when they don't hold the correct pressure anymore you can loose a lot coolant that way.
Jan 6, 2016 at 10:54 PM
