Antifreeze leaking
81,000 MILES • 3.6L • 6 CYL
LONGLEANLADY1
  • 8 POSTS
slow antifreeze leak.
Jul 1, 2019 at 12:54 AM
Hi LongLeanLady1,
Let me know how I can assist with this. If you are just looking how to find it, the best way to find an external leak is to pressurize the system and then start looking for where the coolant is coming out.
Below are some guides that will help with this.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-is-leaking-coolant
If you are just noticing the coolant drop slowly then you will need to identify if there is an external leak or if the engine is burning the coolant. If it is the engine then this could be a head gasket issue.
Let me know if you need more information or give me the detail on what you have. Thanks
Jul 1, 2019 at 11:02 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just a question first. Have you noticed any leaks externally like puddles on the ground or under the car where you park? Or is the coolant just disappearing? Get back to me soon and I will help diagnose the problem. Hope this helps and thanks for using 2CarPros.
Danny-
Jul 1, 2019 at 11:11 AM
LONGLEANLADY1
  • 8 POSTS
there is a small leak on the ground near the center of the car. it doesn't smell like antifreeze and the car is not overheating. not sure what it is.
Jul 2, 2019 at 6:23 AM
LONGLEANLADY1
  • 8 POSTS
there's a small leak under the center of the car on the ground. it doesn't smell like antifreeze and the car isn't overheating. any thoughts?
Jul 2, 2019 at 7:00 AM
If it is a clear liquid with no antifreeze then if it is there after the car was running it is most likely condensation from the AC system. If coolant is not dropping in the bottle then I would just keep an eye on the level and see if it drops. If not I would not worry about the clear liquid.
Jul 2, 2019 at 7:05 AM
