Yes, your vehicle should be okay, especially if you only added a small amount to top off the coolant reservoir. I would not be overly concerned.
However, the 2009 Honda Odyssey requires Honda Type 2 antifreeze/coolant, which is a silicate-free, phosphate-enhanced coolant specifically formulated for Honda's cooling systems.
Just because a coolant is safe for gasoline engines does not necessarily mean it meets Honda's coolant specifications.
If you only added a few ounces, immediate engine damage is very unlikely. Never remove the radiator cap while the engine is hot.
Can you please tell us approximately how much antifreeze you added and whether you added it directly to the radiator or the coolant reservoir?
Nov 24, 2026 at 5:25 PM
