Losing antifreeze from the overflow tank
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
DPLOTT88
We changed the antifreeze and used antifreeze flush to see if it would help. Still losing antifreeze. Have found no leaks.
Jun 1, 2020 at 10:58 AM
I suspect you have a head gasket issue. You need to start with checking for a blown head gasket using the attached guide.
Let us know what you find. There are a number of other causes but those are less likely and are normally accompanied by other issues. Is there any history to this? Did the engine overheat at any point?
Jun 1, 2020 at 11:18 AM
DPLOTT88
No, our car has not been overheating.
Jun 2, 2020 at 1:40 AM
Okay. That is good but doesn't rule out a head gasket. Let's run the test from the guide above and rule it out for sure and then we can go from there.
Jun 2, 2020 at 12:26 PM
DPLOTT88
I'm not sure my husband can do all this as he's disabled.
Jun 2, 2020 at 1:20 PM
Oh, okay. We will help as much as possible but unfortunately this is not the easiest work to do. If he is not comfortable doing it then it may be best to seek some assistance.
Jun 3, 2020 at 1:12 PM
