coolant type?
150,000 MILES • 2.2L • 4 CYL
CAROLYN DAVIS2
I bought synthetic antifreeze and was told it is not for my car.
Jan 6, 2017 at 12:20 AM
HMAC300
  • 48,601 POSTS
You are okay to use that kind of coolant here is a guide to help you flush the system and refill it with DEXcool. Here is what the book says.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
ENGINE COOLANT
A 50/50 mixture of clean water (preferably distilled) and use only GM Goodwrench(R) DEX-COOL(R) or Havoline(R) DEX-COOL(R) (orange-colored, silicate-free) coolant, or an approved recycled coolant conforming to GM Specification 6038-M (GM P/N 1052103).
Jan 6, 2017 at 1:48 AM
JOHANNA23
What happens when you mix two kinds of radiator fluid and what should you do if this happens?
Jan 19, 2019 at 8:49 AM (Merged)
MMPRINCE4000
  • 8,548 POSTS
If you mix them and they are not compatible, you will know very quickly.
Do not mix Dex-Cool or HOAT coolant.
Drain and flush cooling system, use recommended coolant.
KJOHNSON8978
My car sometimes overheats but I think its because I need to put antifreeze in it. There is a leak in the overflow somewhere and the heater core may need replaced but I figure antifreeze should be better than pouring water in it constantly.
  • 75,988 POSTS
The green stuff by Prestone 50/50
RIVERMIKERAT
  • 6,106 POSTS
You need to see if the supposed 100K mile type of antifreeze is in it. No matter what kind, I prefer Prestone, but Peak is also very good.
RYANMOORE
The car says dexcool only dose this mean I can put any kind of coolant in it
CJ MEDEVAC
  • 11,000 POSTS
It sort of means use Dexcool and nothing else!
The Medic
JUDYCORLEY
Does the type of antifreeze cause the car to run hot?
Jan 19, 2019 at 8:50 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2aaddedf23="Judycorley"]Engine Cooling problem
2002 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 135000 miles
Does the type of antifreeze cause the car to run hot?[/quote:2aaddedf23]
It may be possible. I ran into this one time. The person flushed there system and put the regular Green anti-freeze in it. The vehicle started overheating, they changed the thermostat and radiator. Still overheated they called me and I checked the system ran vehicle to see if the was a possibility of an air pocket that was causing the over heating so I then reflushed system and put correct anti-freeze in it and no more overheating.
I would suggest you jack up vehicle run vehicle for a while and then turn vehicle off let cool check coolant if low fill and see what happens. Just don't let vehicle overheat to point of possible damage.
Jacking up vehicle will help any air pockets to work to the top or highest point of engine
