Anti theft system preventing car from starting
187,000 MILES • AUTOMATIC
TONYA HUDSON2
  • 15 POSTS
Went into the store to grab a bag of ice came back to the car and tried to cut the car on and the car would not start it only clicks. On the dashboard everything comes on and says "Anti Theft Security System Problem, Car May Not A" on the dashboard. Please give me a solution to this problem.
May 9, 2021 at 12:39 PM
Good evening,
The first thing I would do is check the battery. Low voltage will cause this issue.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
If the battery tests okay, then I attached a guide for the security system reset. Try this only if the battery is 12.4 to 12.6 volts:
https://www.2carpros.com/articles/how-to-reset-a-security-system
May 9, 2021 at 1:11 PM
