anti theft system activate not start and rear lights stay on
123,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
SALVADOR LOPEZ
Won't start
and lights stay on blinkers do not work also reverse lights l, what to check for ??
Feb 23, 2016 at 1:30 PM
WRENCHTECH
  • 20,760 POSTS
You won't need reverse lights if you can't get it running so tackle one problem at a time. How do you know you have a security problem?
Do you have a security indicator on or flashing?
Have you tried a different key?
Feb 23, 2016 at 10:14 PM
SALVADOR LOPEZ
Hello Thanks To Take The Time And Help Me With this problem With my car. Yes anti theft light is blinking fast.
and also I have tried different key too, and still the won't start problem.
Feb 24, 2016 at 2:31 PM
WRENCHTECH
  • 20,760 POSTS
You have pretty much reached the limit of what you can do yourself. From this point you are going to need a factory level scan tool for diagnosis and likely will have to do some programming when the problem is repaired.
Feb 24, 2016 at 5:56 PM
