Dashboard light is blinking as if an anti theft is active and the car is not cranking.
May 7, 2019 at 2:23 AM
BMDOUBLE
✓Experienced Mechanic
The passive anti theft system is preventing the vehicle from being started due to any one of several reasons. The first step is to retrieve trouble codes from the power-train control module, the code or codes that are retrieved will lead us to the right direction that diagnosis will need to go.
May 7, 2019 at 2:43 AM
RENEE L
MEMBER
Hi STHEMBISO SHELEMBE,
In BMDOUBLE's answer he mentioned retrieving codes. I have included a link for you if would like to see how to retrieve the codes yourself. I also included a tutorial from our YouTube channel showing the procedure.
