Anti theft locked my car - security system problems?
RHAENTJ
  • 1996 HONDA ACCORD
  • 4 CYL
  • FWD
  • 190,000 MILES
My car was stolen. When I got it back the motor in the drivers seat was gone. I cant reach the pedals now. Is there anyway to manually move the seat? They also broke my power locks. When I try to lock the drivers side by the keyless entry or pushing the lock down it makes a really wierd noise. Is there a way to cut off the power so I can manually lock it. I dont car about have power seats or locks I just want to be able to reach the pedals and lock the doors. Thanks for the help.
Saturday, September 26th, 2020 AT 1:29 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi rhaentj,
The power lock producing a weird noise is usually cause by a faulty door lock actuator. The gears are overshooting and actuator is not stopping in time.
To disable the power lock, you can remove the underhood # 38 fuse or unplug the power door lock control unit in the driver's door, behind the panel.
Without the seat motor, you would have to use something to manually turn the motor linkage for adjusting the seat, located under the seat, to get the seat forward.
BBYERS
  • 1995 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 157,000 MILES
I've cleaned the battery posts on a 1995 Honda Accord LX. It appears a security system has engage and won't allow me to start the car. How do I turn off the security system after disconnecting the battery?
KHLOW2008
  • 41,814 POSTS
Hi bbyers,
TRANSMITTER PROGRAMMING
1. Open driver's door. Press and hold driver's master power door lock switch in the UNLOCK position. Within 10 seconds, insert and remove key from ignition switch 5 times. On the sixth key insertion, leave key in ignition switch. All doors should unlock, indicating system is now in programming mode.
2. Press either button on the transmitter. All doors except driver's door will lock and unlock indicating system has accepted transmitter into its memory. If either transmitter button is pressed again, all doors will lock and unlock.
3. To program a second transmitter, press either button on that transmitter. The doors will lock and unlock indicating that the second transmitter has been accepted into the system memory. Release driver's master door lock switch.
4. To exit the programming mode, close driver's door or remove key from ignition switch. Check door lock operation at both front door locks. If door locks door not function properly, repeat programming procedure.
Page 1 of 1 DOOR LOCKS - POWER & TAILGATE RELEASE -1995 Honda Accord EX 9/7/2008
HONDAKID
What if you have the same problem, but dont have power locks? My car is manual and locked up. If I charge up the battery it beeps if I mess with anything. Need help please!
