Anti-theft light flashing, immobilizer?
185,000 MILES • AUTOMATIC
KOFFEEBLAQ
Battery replaced by previous owner. Fob is still working but the car won't turn on. Radio doesn't seem to turn on either. Backlight on dash illuminates but no warning or indicator lights show. Starter replaced.
Jan 31, 2024 at 1:22 PM
  • 55,694 POSTS
It sounds like the security system is enabled but we should start by checking the fuse with the key on. Also, can I ask if the original key is still with the car or is there a replacement key tried to start the car?
If the fuse is okay with the original key, can I ask if the security light is flashing? If so, I would disconnect the battery overnight to help reset the system.
This guide may help as well:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Check out the images (below). Please upload pictures or videos in your response of the problem so we can see what's going on.
Feb 1, 2024 at 3:51 AM
