More then likely the starter solenoid is failing in cold weather like this. I would try and tap on the side of the starter when this happens and see if it turns over a few more times.
If that is the case then here is a guide that will help with replacing it.
https://youtu.be/5Jd2-wfIKOw
Also, here is another guide that will help with this issue if the starter is not the solution:
Lastly if this is happening only when cold, we should load test the battery just to make sure it can carry the proper load.
Let us know what you find. Thanks
Jan 29, 2021 at 7:43 AM
