Anti theft is triggered
2001 JEEP GRAND CHEROKEE
200,000 MILES • 3.1L • 6 CYL • 4WD • AUTOMATIC
JEFF WRIGHT2
Do they make an aftermarket ECU that doesn't have antitheft in it?
If so can you hook me up with a url,or if i can get a schematic of the ecus motherboard and location of the anti-theft system? thank you
May 18, 2019 at 11:50 AM
JIS001
  • 3,412 POSTS
There is no aftermarket ECU that will bypass the sucurity. If you can have the anti theft codes scanned and post the codes on here then we can better assist you as to what you need to check.
May 18, 2019 at 3:06 PM
