I do not have the key fob or original key and it will not start
2005 TOYOTA AVALON
1,500,000 MILES • 3 CYL • 2WD • AUTOMATIC
BECKY TAYLOR
MEMBER
1 POST
I just bought this car and had to change the Ignition because my friend lost her key. What should I do?
Nov 8, 2019 at 12:56 AM
MASTERWRENCH
✓Experienced Mechanic
Assuming you now have a functional key that works with your new ignition switch, you'll need to get your new key programmed to the vehicle. This is something that typically needs to be performed by a dealership.
Nov 8, 2019 at 11:24 PM
