Anti theft deterrent?
64,753 MILES • 3.6L • V6 • AUTOMATIC
CHAPOE23
All my gauges and the A/C does not work, and it says anti-theft deterrent.
Mar 16, 2025 at 7:22 PM
  • 55,721 POSTS
This happens when the system is enabled. I would do a hard system reboot to reset the system.
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Does your key fob have new batteries? Have you tried your spare key? I would start by checking the fuses, here is a guide to help and the fuse locations in the images below:
Check out the images (below). Let us know how it goes.
Mar 17, 2025 at 5:23 AM
CHAPOE23
No i did everything that you suggested and nothing happened. Still does the same thing.
Mar 18, 2025 at 5:16 AM
  • 55,721 POSTS
Okay, it look like the BCM might be out, I would do a CAN scan you see if any codes are stored. Please go over this like to see how:
https://youtu.be/u-4syLc-ifQ
Here is the locations of the BCM so you can check it out, I would remove the electrical connectors and look for corrosion, disconnect the battery first. If a code is stored for the BCM you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Let us know how it goes.
Mar 19, 2025 at 3:15 AM
