Anti-theft light on after removing the dash?
100,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
ARIANADANIELLE5345
  • 402 POSTS
Removed dash to change heater core, now no crank no start, not fuel pump prime. Tested with probe and there’s power to the starter and the pump and if I bump the starter, it cranks but won’t start. Anti-theft light is on, so I tried all of the reset procedures, but nothing is working. Tried changing the ignition lock cylinder because it came with new keys, but nothing. Tried changing ignition switch, still nothing. I don’t know what else to do.
Jan 14, 2023 at 8:06 AM
  • 55,743 POSTS
When you removed the dash did you plug back in the main electrical connectors? There are grounds wires as well that need to be hooked up so please recheck your work. Also have you checked the fuses with the key on.
Here is a guide to help:
We should run the codes if the fuses are good. I would do a CAN scan which is easy to do, you can get a CAN scanner (Controller Area Network) from Amazon from about $32.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Amazon CAN scanner Link.
https://amzn.to/3G7mpFP
You can try a hard reboot which is done by removing the negative side of the battery, with the cable loose from the negative side of the battery, hold it to the positive terminal for 1 minute this will discharge the memory capacitors in the BCM and PCM allowing the system to reboot. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Jan 15, 2023 at 2:50 AM
ARIANADANIELLE5345
  • 402 POSTS
I already tried all of that and already checked all of the fuses. I have an Autel 508, the key writing computer. no code pertaining to why it won’t start comes up on the screen.
Jan 15, 2023 at 5:46 AM
ARIANADANIELLE5345
  • 402 POSTS
The anti-theft light is illuminated on the dash, so it has to have something to do with that. I tried resetting it with the re learn procedure and still nothing.
Jan 15, 2023 at 5:48 AM
  • 55,743 POSTS
When you try to crank it over does the security light flash? If not that might not be the problem it is flashing then yes, it is in lockout mode. Here is information on the security system that can help.
LEARN PROCEDURES
There are 2 available methods to perform the programming procedure:
- A 10-minute procedure which requires a Tech 2 and a techline terminal.
- A 30-minute procedure which does not require the use of any tools.
10-MINUTE LEARN PROCEDURE
1. Connect the Tech 2 to the vehicle.
2. Select Request VTD Info. for SPS under Special Functions in the Body Control Module menu.
3. Disconnect the Tech 2 from the vehicle and connect it to a techline terminal.
4. On the techline terminal, select Theft Module Re-Learn under Service Programming.
5. Disconnect the Tech 2 from the techline terminal and connect it to the vehicle.
6. Turn ON the ignition, with the engine OFF.
7. Select VTD Re-Learn under Service Programming.
8. Attempt to start the engine, then release the key to ON, vehicle will not start.
9. Observe the SECURITY telltale. After approximately 10 minutes, the telltale will turn OFF. The vehicle is now ready to relearn the Passlock(TM) Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK.
10. Turn OFF the ignition, and wait 5 seconds.
11. Start the engine, the vehicle has now learned the password.
12. With the Tech 2 scan tool, clear any DTCs.
30-MINUTE LEARN PROCEDURE
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON, vehicle will not start.
3. Observe the SECURITY telltale. After approximately 10 minutes, the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock(TM) Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
6. Start the engine. The vehicle has now learned the Passlock(TM) Sensor Data Code and/or password.
Let me know please.
Jan 16, 2023 at 7:26 AM
ARIANADANIELLE5345
  • 402 POSTS
I tried both of those already and no it doesn’t flash it just stays illuminated constantly.
Jan 16, 2023 at 8:01 PM
  • 55,743 POSTS
Okay, that is normal. When you installed the new key lock were the keys programmed to the truck? If not, this will be the problem. To be sure let's do a CAN scan which will come up with a code. You can get a CAN scanner (Controller Area Network) from Amazon from about $32.00.
and
Jan 17, 2023 at 7:01 AM
