anti-theft
180,000 MILES
BRELANDF
Keylesss multi remote unit will not deactivate the anti theft when I use the key to unlock the door the anti theft unit activate and when the alarm stop the car will not start the anti theft has disable the starter is there anyway to bypass the anti theft system .its a factory install system
Apr 14, 2013 at 6:06 AM
if it is a factory fob, it has either a dead battery, it has failed or needs to be reprogrammed by the dealer.
if it is aftermarkt there may be a failure in the system that you need to take it to an alarm shop for repair.
Apr 14, 2013 at 6:41 AM
