ABS warning light comes on while driving and stays on for a while and then goes off. Also, a message appears saying to service traction control.
Dec 11, 2017 at 11:58 AM
HARRY P
✓Experienced Mechanic
You will need to get it scanned and see what fault codes come up. If I were a betting man, I would bet on a problem with a wheel speed sensor. But since you have four of them you do not want to just start replacing them all. So take it to the dealer or a mechanic with a scanner that can read ABS codes and see what comes up. Let us know and we will go from there.
