Antenna
300,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
RONALD WOODS
  • 12 POSTS
Antenna raises and lowers but makes grinding sound when it reaches end of cycle.
Mar 24, 2018 at 12:21 PM
WRENCHTECH
  • 20,760 POSTS
That means that the gears on the spine are likely stripping. You can replace just the mast and spine but there may be more damage than just that.
Mar 25, 2018 at 1:23 AM
RONALD WOODS
  • 12 POSTS
What other damage could it be?
Also, my left door is not closing properly have to slam to make sure it is closed. Driver side door.
Mar 25, 2018 at 5:09 AM
WRENCHTECH
  • 20,760 POSTS
You may have to replace the whole antenna with motor instead of just the spine. You need to start a new question for your door issue.
Mar 25, 2018 at 5:11 AM
