Ancestors 610 Elite code reader says “stop engine “?
2003 GMC SONOMA
150,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
DOOB
  • 72 POSTS
Trying to check ABS pump solenoids. My ancestors scanner says “stop engine “ but engine isn’t running. So can you explain this code?
Jan 29, 2021 at 7:35 AM
  • 110,244 POSTS
Can you tell me what code you are getting? Also, what are the symptoms you are experiencing? Also, I'm not familiar with a 610 Elite scan tool. Is it something that can read codes other than engine codes?
Jan 29, 2021 at 12:27 PM
DOOB
  • 72 POSTS
It reads codes and does ABS auto bleed?
May 4, 2021 at 1:21 PM
DOOB
  • 72 POSTS
It’s s Ancell elite. 610. My stupid phone wrote ancestors. Lol
May 4, 2021 at 1:23 PM
DOOB
  • 72 POSTS
Now I’m back to the Pontiac Grand Prix rack problem.
May 4, 2021 at 1:24 PM
  • 110,244 POSTS
Will the scanner read codes other than powertrain codes? Do you know if it can be used to scan the can-bus system? Also, is there a code related to the "stop running" message you are getting?
May 5, 2021 at 12:06 PM
