1988 AMC Eagle wont start
84,780 MILES • 6 CYL • 4WD • AUTOMATIC
ED HELLWEG
red wire to small post on solenoid that is hot when key is on gets hot at terminal onsolenoid and voltage drops way off at coil post when u try to start it it will have one good spark as u start to turn engine over and again just as u release key if u disconnect the dist at plug in u have full voltage not distributor
Aug 9, 2009 at 3:51 AM
DESERTDOG
  • 8 POSTS
Ed, It sounds like the solenoid may be shorted internally. The red wire should only be hot while cranking. Dog
Aug 17, 2009 at 5:56 AM
BARRACKVILLE
  • 8 POSTS
SOUNS LIKE IIHE IGNITION MODULE NEED REPLACED
Sep 29, 2010 at 5:58 AM
