red wire to small post on solenoid that is hot when key is on gets hot at terminal onsolenoid and voltage drops way off at coil post when u try to start it it will have one good spark as u start to turn engine over and again just as u release key if u disconnect the dist at plug in u have full voltage not distributor
Aug 9, 2009 at 3:51 AM
