1987 AMC Eagle stalls
122,000 MILES • 6 CYL • 4WD • AUTOMATIC
OREGONCOWGIRL
when i start the car up it warms up then when i am driving it for awhile and i am stoped at a stop light it has been dying (stalling) i then have to restart it and it is driving fine till i come to a stop then it dies again on me can you please help me thanks!
Jul 26, 2009 at 4:38 AM
  • 110,248 POSTS
Chances are you have a vacuum leak. It was a common problem. Check for a leak. If the engine is running, you may hear a hissing sound.
Let me know what you find.
Oct 30, 2009 at 5:11 AM
BARRACKVILLE
  • 8 POSTS
CHECK THE DASH POT ON CARB,THIS LETS THE IDLE ,WHEN COMING TO A STOP, SLOWLY CLOSE THE THROTTLE PLATES THUS KEEPING FROM STALLING,IF OK CHECK AROUND THE THROTTLE SHAFT FOR VACUM LEAK,IF THIS IS IT REBUSH SHAFT OR REPLACE CARB.
Sep 29, 2010 at 5:53 AM
