1982 AMC Eagle quits
299,999 MILES • 6 CYL • 4WD • AUTOMATIC
REDGREENED
i got a 82 anc when u start it it will run for 15-20 min than quit and wont start when it wont start there is no power to the coil it has a new ignishen modgual i just cant figure it out
May 20, 2010 at 6:53 AM
  • 75,988 POSTS
Try this run a jumper wire from the battery positive post to the coil positive terminal and see what happens if it fires up its coming from the ignition switch
May 20, 2010 at 9:02 AM
