1982 AMC Eagle carburator
92,500 MILES • 6 CYL • 2WD • AUTOMATIC
EAGLE82
the carb is sputtering bad started a few days ago tried new fuel filter dry gas and new spark plugs and check for any deposits in dist. cap but knocked coil of rotor how do i get new coil and what may be causing the sputter
Jan 25, 2009 at 4:10 AM
  • 110,248 POSTS
Do you need a rotor or a coil?
Oct 30, 2009 at 5:12 AM
BARRACKVILLE
  • 8 POSTS
CHECK CARB ITSELF THESE ARE REAL BAD ABOUT SHAFT LEAKAGE,SPRAY A LITTLE CARB CLEANER AROUND THE THROTTLE SHAFT AND BASE,IF IDLE SPEED PICKS UP YOU MAY HAVE A VACUM LEAK
Sep 29, 2010 at 5:45 AM
