can i add on-off switch connect to the main switch power and use solar power inventor 5000 watt or 12v generator
60,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
AZZAM12AZZAM
  • 86 POSTS
Since all lights and air condition and refg doesn't operate when the switch is off does any body know how I can solve this problem? I converted to RV I need travel. can i add on-off switch connect to the main switch power and use solar power inventor 5000 watt or 12v generator? so i can use the utilities when I am in dessert or else what other options? especially i understand rear air-condition could be no way to use it when switch is off. This is an ambulance converstion.
Thanks
Nov 27, 2019 at 3:48 AM
SCGRANTURISMO
  • 4,897 POSTS
Sure you could. I wouldn't hook it to main power switch, though, I would buy a bus bar and then run wires from the bus bar to the components that you want to power with the power source. Put the on/off switch inline in between the power source and the bus bar. I hope this helps.
Thanks,
Alex
2CarPros
Nov 27, 2019 at 9:44 AM
AZZAM12AZZAM
  • 86 POSTS
Thanks Alex, I am trying to avoid putting more wires because the car is already loaded with punch of wires. usually when am driving I don't need the power inside. I needed only when I stop in places for one or two days. can I cancel the main switch and hooked to solar invertor or other wise I will follow your advice. but how I can solve the rear air-condition when engine is off or I have to buy external air-condition especially am trying not to make holes in the sailing .
thanks again Alex I highly appreciated your respond.
Nov 28, 2019 at 6:08 AM
SCGRANTURISMO
  • 4,897 POSTS
Yes you will either have to buy an external Air Conditioning Unit or idle your vehicle's engine. In order for your vehicle's A/C to be on the engine has to running. I hope this helps.
Thanks,
Alex
2CarPros
Nov 28, 2019 at 12:12 PM
