My ambient temperature is showing 12 degrees when it is around 24 degrees. What could be the problem and is this likely to cause issues elsewhere?
Sep 15, 2023 at 9:16 PM
✓Experienced Mechanic
Sure, this happens when the ambient air temperature sensor goes out, here is the location so you can swap it out.
Ambient Air Temperature Sensor
Removal
Note: Removal steps in this procedure may contain installation details. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Sep 18, 2023 at 4:29 AM
KJADE8911
MEMBER
Thank you for your reply, if I can't fix this just yet, is it likely to cause any major problems? Thanks
Sep 18, 2023 at 4:45 AM
Not really, it might make the climate control work a little funny.
