Ambient temperature sensor?
166,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Can this sensor, if bad or cut affect engine temperature or cluster needle in any way?
Apr 15, 2025 at 6:53 AM
  • 110,248 POSTS
If you are referring to the outside ambient air temperature sensor, no, it wouldn't affect the engine temperature or cluster gauge. The outside ambient temperature sensor is connected with a separate ground (analog ground) and a sensor line (analog positive) to the instrument cluster and functions in an on/off every minute.
What is happening with the vehicle? Are you having an overheating issue?
Let us know.
Apr 15, 2025 at 11:24 AM
BHAMDOC1973
  • 2,007 POSTS
turned out one of the upper hoses going to the expansion tank wasn't fully in and leaking. Thanks
Apr 18, 2025 at 4:38 AM
  • 55,710 POSTS
JACOBANDNICKOLAS is one of our best! Glad you could get it fixed, thanks for letting us know.
Apr 21, 2025 at 2:36 AM
