Ambient sensor location
87,123 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JESSICA VINNY ARREDONDO
  • 7 POSTS
Where is the outside ambient sensor located at?
Mar 6, 2019 at 5:00 AM
Good afternoon,
It is behind the grille at the front of the truck. I attached a picture for you.
1. Disconnect and isolate the negative battery cable. If equipped with an Intelligent Battery Sensor (IBS), disconnect the IBS connector first before disconnecting the negative battery cable.
2. Disconnect the wire harness connector (3) from the ambient air temperature sensor (2).
3. Remove the push pin (1) that secures the ambient air temperature sensor and remove the sensor.
Mar 6, 2019 at 6:15 AM
  • 7 POSTS
Mar 6, 2019 at 1:21 PM
You're welcome.
Always glad to help.
Mar 6, 2019 at 4:16 PM
