AM2 fuse keeps blowing
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
DADDYHERB
  • 6 POSTS
I tried to jump start a lady in the rain, with no luck. I pulled out and made it half a mile down the road. My car shut off. My am2 fuse had blown. I have unplugged the coil packs, unhooked the alternator and starter. One at a time and still blew the fuse when I tried to start it. I replaced the ignition switch yesterday, but still the same. I have traced all the wires the best I can and can not find a bad spot in any of them. Any ideas?
Jun 19, 2017 at 3:55 AM
STEVE W.
  • 15,421 POSTS
Test the injectors for a shorted one or more. They are the only item directly fed from that fuse. The other circuits it feeds are fused at a much lower amperage.
Jun 19, 2017 at 5:02 AM
DADDYHERB
  • 6 POSTS
The injectors? Okay. That is one I have not tried. can I unplug them and test that way, or will I need someone with a meter?
Jun 19, 2017 at 5:18 AM
STEVE W.
  • 15,421 POSTS
Stick a test light in place of the fuse, then pull the connectors one at a time. The light should come on bright and dim a lot or go out once you pull the shorted injector connection.
Jun 19, 2017 at 5:49 AM
DADDYHERB
  • 6 POSTS
I spent hours going over wires, over and over. Had four people come look at the car, two "knew" what they were doing. No luck. The second injector I unplugged, the car started right up. I can't thank you enough. You Mr Steve are a life saver and damn sure an Expert.
Jul 31, 2017 at 7:31 AM
STEVE W.
  • 15,421 POSTS
You are very welcome, glad to hear that you discovered the problem.
Thank you for using 2CarPros.com Come back with any other automotive questions and tell your friends about us. Please.
Jul 31, 2017 at 7:59 AM
DADDYHERB
  • 6 POSTS
I will
Jul 31, 2017 at 8:01 AM
