AM radio static when ignition is switched on.
220,000 MILES • 2.3L • V6 • 4WD • AUTOMATIC
BELLAROSAARTIST
AM radio static
1. turn on ignition prior to starting.....buzz in am radio signal.
2. start engine......more buzz in am radio signal. result: cannot use am input.
3 fm ok.
Nov 9, 2015 at 2:59 AM
  • 110,248 POSTS
A distinct buzzing noies which rises and falls with engine speed and is worse with AM reception is usually the result of either a bad radio ground or worn spark plug wires. Make sure the radio is properly grounded and check the antenna to make sure there is no corrosion causing a loss of ground. If all grounds seem good, question the engine's ignition system. Most likely the noise is from worn plug wires causing an electrostatic interference.
Nov 9, 2015 at 9:49 AM
