not cranking over
27,000 MILES • FWD • AUTOMATIC
STEPHENIFEANYI
what make the gear light stop showing and the check engine light as it makes the engine can not even crank?
Nov 14, 2016 at 5:26 AM
JIS001
  • 3,412 POSTS
Can you post a picture of the gear light to see what you are talking about? Check engine light illuminates and should go off once you start it. If it still stays on you will need to scan it for fault codes.
As for vehicle not cranking over, verify battery is good. You could have a faulty starter if it does not crank over.
Nov 14, 2016 at 6:29 AM
STEPHENIFEANYI
the car battery is okay and the starter too, but the check engine light that was supposed to come when put ignition is not coming on.
Nov 14, 2016 at 6:34 AM
JIS001
  • 3,412 POSTS
What size engine do you have? Also hybrid or none hybrid?
Nov 14, 2016 at 7:04 AM
