Always shuts off when driving?
2003 NISSAN ALMERA
1,556 MILES • 0.8L • 4 CYL • 2WD • MANUAL
OWENG
When I pass through a bump it will cut out n then return back when I pass through gallop the same thing happens.
Nov 9, 2022 at 3:22 AM
  • 110,244 POSTS
We have a loose connection or even a cracked solder joint in one of the printed circuit boards.
Have you ever had the computer scanned to determine if there are any diagnostic trouble codes stored? Because of the nature of the issue, it could be many different things. If there are codes stored, it may lead us in the right direction.
If the check engine light is on while the engine is running, stop at a parts store and have them scan the computer. Most do it free of charge.
Here is a quick video showing how it is done:
https://youtu.be/b2IJGfImVvw
Let me know. Also, if you find codes, let me know what they are.
Nov 9, 2022 at 9:35 AM
