Alternator will not charge while at a stop light
144,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
TROUBLE1980
  • 49 POSTS
Hi, I just replaced my alternator with a 140 volts one because I thought my old 80v/100v one wasn't enough to power my car, but I'm having the same problem. my problem is, it is fine while at idle in park 13/14v with or with out the headlights on but as soon as I put it into Drive with my foot all the way on the brake it gradually drops to red line within 25 seconds. Now if i put it in park and take my foot off the brake it goes right back up to 13+v. While driving its at 13+v. Not running anything but the engine, fan and headlights.
Please any suggestions would be appreciated!
Mar 31, 2019 at 1:32 PM
  • 110,248 POSTS
Welcome back:
I was waiting and watching for this. LOL Ready for bed here. Anyway, is the engine idle speed when it's in gear and stopped low? I attached two pictures. One indicates idle speed if the engine is fuel injected and 2 shows if it has a carburetor. Take a look at them and see if it falls within the specs. Also, make sure the alternator belt is tight.
Next, I need to know what type of alternator was replaced because they have different types of voltage regulators. See Picture 3.
Let me know,
Mar 31, 2019 at 1:58 PM
TROUBLE1980
  • 49 POSTS
Hey my good Friend Joe!
I'm not sure what its idling at, it has a 350 sbc in it and the rpm gauge isn't working properly! And the belt is tight it has absolutely no give. The battery stay's at 13v+ until I'm in drive and completely at a stand still, then drops all the way to red line , I can hear and feel the motor gradually slow down. But while in park and with foot off the brakes there is absolutely no problem. It idles fine.
Mar 31, 2019 at 2:08 PM
TROUBLE1980
  • 49 POSTS
Power master not 100% sure what the previous one was I replaced. all I know is I bought the old one from DB electric.
Mar 31, 2019 at 2:11 PM
  • 110,248 POSTS
Okay, what I need you to do is this: When the engine is running, check voltage at the alternator itself. You will need someone to hold his foot on the brake and have it in gear for you. I have a feeling you got an alternator with a bad regulator. IF the RPM's are within spec, you check voltage at the alternator and it's low, the regulator isn't good. Please keep in mind, low RPM's or a loose alt belt can cause this.
Let me know,
Mar 31, 2019 at 2:23 PM
TROUBLE1980
  • 49 POSTS
Okay, Joe. I will check this tomorrow and let you know , I recently purchased a multi-meter only bought a new alt because I was having same problem with old one.
Mar 31, 2019 at 2:25 PM
CARADIODOC
  • 34,414 POSTS
First put the right generator back on. No generator will develop more than the electrical system demands. What you have done is added more capacity to the system. You won't get more current except under only one condition. That is during a full-load output current test with a professional load tester.
The second law of AC generators is they are physically incapable of developing more current than they are rated for. If your car came with a 100-amp generator from the factory, there is going to be a fuse link wire spliced into the output circuit going back to the battery that was sized according to the size of the generator installed. By installing a replacement generator with a higher capacity, if the electrical system needs 43 amps, for example, the largest generator in the world is going to develop exactly 43 amps, except during that brief output current test. That is intended to run the generator at its maximum output for a few seconds. A 140-amp generator will develop close to 140 amps, and that is going to burn out the fuse link wire. Newer vehicles use large bolted-in fuses for this circuit. Older vehicles like what I drive still use those fuse link wires. In some cases those are hidden in the wiring harness, and when you do find it, they are quite time-consuming to replace.
What you have going for you is the engineers at GM redesigned their generators for the '87 model year and turned them into a real pile. The '86 and older unit is, in my opinion, the world's second-best design. There's two common things that can cause the symptoms you described. The first is a slipping drive belt. Checking that is easy on GM and Ford vehicles. They use an external fan blade right behind the pulley. Of course you will do this with the engine not running! Use your thumb to push on the fan blade. If you can get it to slip under the belt, the belt is too lose, or it is worn down too far, or it's the wrong belt. If your generator still uses the reliable V-belt, those need to wedge into the pulley so it will grip on the sides of the belt. You can get a skinnier belt, or one that is worn down, then it will run on the bottom of the groove in the pulley. There's no grip there.
To add to the misery, all generators require three things to work. That is a wire, (coil of wire), a magnet, (we use an electromagnet), and most importantly, movement between them. As a result, all generators are very inefficient at low speeds. Even though the belt is slipping, it is still running the pulley faster at higher engine speeds. That could be one reason you only see the low charging voltage at idle.
The second common problem that only pertains to GM generators is a defective diode trio. Current flow through the dash warning light gets this system started, then once it's producing current, a tiny sample of that is tapped off and goes through the diode trio. That develops a little current that keeps the electromagnetic field energized until you stop the engine. The voltage it develops has a second function. That is to turn the warning light off. The clue here when one of those three diodes fails, is it only turns the light off two-thirds. The often-overlooked symptom is the warning light is still lit up very dimly. Quite often you can only see it glowing at night.
The issue here is that is the current that runs the generator, and it is cut by one third. Under that full-load output current test, which you need a professional load tester for, your 140-amp generator will only be able to produce close to 90 amps. That standardized test is run at 2,000 rpm. At idle, that output current will be even less, and if it can't keep up with demand, system voltage is going to slowly drop as the battery takes over to make up the difference.
Another part of the tests can actually confuse this problem. That is measuring charging voltage. You can do that with an inexpensive digital voltmeter. With the engine running, you must find battery voltage to be between 13.75 and 14.75 volts. When you have a defective diode trio, the internal voltage regulator sees that dip in voltage when current is supposed to be coming through the failed diode. It responds by bumping up charging voltage a little. That can offer a clue on some cars. You might find battery voltage to be closer to 15.0 - 15.2 volts. That's not enough to boil the water out of the battery, but we want to correct that.
When you find charging voltage in the acceptable range, that only means it is okay to perform the rest of the tests, but that requires a professional load tester. There's another chapter related to low output current. All AC generators use six main diodes to turn the alternating current into direct current that can be stored in a battery. When one of those diodes fails, you will lose exactly two thirds of the generator's output capacity. That is less affected by lower engine speeds, but 35 amps from your original 100-amp generator is not enough to run the entire electrical system under all conditions. Again, the battery will have to make up the difference until it slowly runs down over days or weeks. You may also see this as low voltage at idle. The professional load tester checks for this. Also, with one of these failed diodes, "ripple voltage" will be very high. A few testers make a printout and they show a specific value for ripple voltage. Most testers just show it on a digital relative bar chart. On the newer generator design, replacing any internal part is a lesson in frustration, and it is not practical even for an experienced mechanic. With yours, these output diodes are replaced in two blocks, each with three diodes. The diode trio is a very inexpensive part that is just bolted in once the unit is apart. I can post photos if you need to tackle that job.
For my last comment of value, do not take a generator to a parts store for testing. At most, those have a one horsepower motor to run the generator, and they can't do that at a raised speed that is necessary for proper testing. On the engine, it takes a good five or more horsepower to run a generator. When it can't be run under full load for a few seconds, ripple voltage will not be as high as we need it to be to know it is bad. Complete on-car testing of the charging system only takes a minute or two when it's working properly, and usually just a few additional minutes to diagnose the common problems.
You can find more dandy information here:
Mar 31, 2019 at 3:05 PM
CARADIODOC
  • 34,414 POSTS
Hi Joe. Sorry that I keep on replying after you. This wouldn't happen if I didn't take so long to type my great and wondrous replies.
Mar 31, 2019 at 3:07 PM
TROUBLE1980
  • 49 POSTS
Caradiodoc that is a lot to take in! Sorry to be blunt by I only have basic knowledge of mechanical work and not none at all when it comes to the electrical side of things, lol. But to who ever is helping me with this problem whether it be you or Joe, I did notice something this morning my battery only goes under 13v when it's in drive at a full stop with the headlights on, when in drive with the headlights off and at a full stop it does lower but not under 13v not sure if that helps? Let me know if that changes my outcome could it be something to do with the headlights, and not all the other stuff?
Mar 31, 2019 at 11:47 PM
  • 110,248 POSTS
Welcome back:
How far under 13v with the lights on? If it is still staying above 12v, I would consider that normal. Let me know.
Apr 1, 2019 at 10:10 AM
CARADIODOC
  • 34,414 POSTS
The best approach to start with is having the charging system test done by a mechanic with the load tester. If everything checks out okay, the two of you can continue on with the other possible causes. If you do find there is a bad diode trio or a bad main diode, you will be chasing your tail for an elusive cause while overlooking the actual problem. All you have to do is post the results for "charging voltage", full-load output current", and "ripple voltage". Joe can help you understand those results and the possible causes, or I can come back and do that too.
Be sure to tell the mechanic you have a larger generator installed. The full-load test requires him to apply a real heavy load to the battery for a few seconds, to see how much current the generator is able to develop. That load only needs to be applied long enough to read the digital display, but a normal byproduct of that test is smoke coming out of the tester. Too often we become mesmerized by that, and we lollygag too long. That won't hurt the generator, but it is going to exceed the rating of the fuse link wire and burn it open. That wire is like a delayed-action fuse or circuit breaker. It is going to take a few seconds to burn open. Once your mechanic knows that possibility exists, he is going to be more careful to "get in, get the reading, and get out", before that fuse wire can burn open.
Apr 1, 2019 at 11:05 AM
TROUBLE1980
  • 49 POSTS
Hi, don't get me wrong, I appreciate both of your help! ! As I need different views to help me understand the situation. I believe it would drop all the way to red eventually, would take probably forty seconds. Drove all day this afternoon it was +13 / 14 but as soon as I turn the lights on within fifteen seconds id say its under 12.
Apr 1, 2019 at 11:14 AM
TROUBLE1980
  • 49 POSTS
Also while driving it stays at 13/14 with lights on only drops at stops.
Apr 1, 2019 at 11:18 AM
  • 110,248 POSTS
Okay, that is a problem. If the belt is tight, and the RPM's are within the manufacturer's specs, then the regulator isn't doing its job and providing charging at the lower RPM's. I honestly think you got a faulty alternator.
Apr 1, 2019 at 11:50 AM
TROUBLE1980
  • 49 POSTS
How do I test it with a multimeter? Or can I?
Apr 1, 2019 at 11:53 AM
  • 110,248 POSTS
Here is a link that shows how to check alternator output using a multi-meter or volt meter:
Apr 1, 2019 at 12:28 PM
TROUBLE1980
  • 49 POSTS
Thank you Joe, I'll let you know the out come sometime after 7:00 pm tomorrow.
Apr 1, 2019 at 12:36 PM
  • 110,248 POSTS
Good Luck.
Apr 1, 2019 at 12:55 PM
CARADIODOC
  • 34,414 POSTS
Are you familiar with the "D"-hole in the rear housing? There's a tab in that hole to ground. You poke in a metal screwdriver, pick, or even a cotter pin, to touch that tab, then move sideways to also touch the housing. That bypasses the voltage regulator and lets the generator run wide open. Remember, all generators are very inefficient at low speeds, so don't raise engine speed to prevent burning open the fuse link wire.
If Joe is right, doing this will bring charging voltage back up You'll also hear the engine load down a little, and the generator may "sing" a little to let you know it's really working.
If the charging voltage doesn't change when grounding the tab, the regulator is already running the generator as hard as it can, then the low voltage is going to be due to failed diodes or a slipping belt.
Apr 1, 2019 at 1:32 PM
