Alternator
60,000 MILES • 3.0L • 4 CYL • 2WD • MANUAL
GARRYBARB LOWTHER
Alternator turns one way but not the other.
Nov 6, 2017 at 7:26 AM
  • 55,627 POSTS
It sounds like it is bad and needs to be replaced because of bad bearings.
Here is a guide to show you what you are in for when doing the job:
https://www.2carpros.com/articles/how-to-replace-an-alternator
INSTALL GENERATOR ASSEMBLY
Install the generator assembly with the 2 bolts.
Torque: 43 N.m (438 kgf.cm, 32 ft.lbf)
Install the wire harness clamp bracket with the 2 bolts.
Torque: 8.0 N.m (82 kgf.cm, 71 in.lbf)
Connect the wire harness.
Connect the wire harness to terminal B and install the nut.
Torque: 9.8 N.m (100 kgf.cm, 7.0 ft.lbf)
Connect the connector to the generator assembly.
Install the wire harness stay with the bolt.
INSTALL FAN SHROUD
INSTALL RADIATOR SUPPORT TO FRAME SEAL LH
INSTALL V-BANK COVER
CONNECT CABLE TO NEGATIVE TERMINAL
Torque: 3.9 N.m (40 kgf.cm, 35 in.lbf)
And here is how to replace the alternator on your car (below) I have included both four and six cylinder engines.
You should check the alternator once the job is completed.
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Nov 9, 2017 at 2:39 AM
