Alternator replacement step-by-step instructions needed?
200,000 MILES • 3.4L • V6
DONKEYKIK
Customer wants the alternator tested for proper operation and if faulty, wants it replaced. I wanted to get step-by-step instructions on the replacement of it and in car test of amps and volts with Multi meter. Please and thanks.
Apr 5, 2025 at 9:11 PM
  • 110,251 POSTS
As far as testing the alternator, check the battery voltage with the engine off. It should be approximately 12.5V. With the engine running, recheck the voltage at the battery. It should be between 13V and 15V.
As far as the alternator is concerned, it isn't an easy one. The engine needs to be turned to make the bolts accessible. However, it isn't as difficult as you may think.
If you look below, I attached the rotating the engine directions first. The remaining pictures, starting with the fourth one, are the directions for replacement. Also, labor called for 1.5 hours.
I hope this helps.
joe
Apr 6, 2025 at 7:00 AM
DONKEYKIK
Thank you for this helpful information.
Apr 6, 2025 at 2:55 PM
  • 110,251 POSTS
You are very welcome. I'm glad to know they will help. If you have a chance, let me know how things work out for you.
Apr 7, 2025 at 1:05 PM
