Alternator swap
1989 GMC TRUCK
11,111 MILES • 7.4L • V8
MRAMPS1
I have a 1989 454 in my boat with a 1 wire alternator. l purchased a 220 amp alternator from DB Electrical Item Number: ADR0172-220. it has a 4 pin connector on the side. I have looked up wiring diagrams couldn't find any with 4 pin connectors. Just a brown wire leading to the charge indicator. will this work on my motor?
Apr 26, 2020 at 9:01 PM
  • CAR REPAIR CONTRIBUTOR
Good morning.
No, it will not work at all.
What happened to the original alternator? I would have that one overhauled by a re builder and re install. The 1 wire alternators work great and the output should be able to handle all the current you need.
Apr 27, 2020 at 4:04 AM
